Valve Seals
Old May 20, 2007 | 02:38 AM
ridinhondared's Avatar
Default Valve Seals
i noticed my quad is smoking a little bit. i wanna go ahead and change my valve seals anyways. my question is, is it hard to do? what all is involved? what brand of seals?
Old May 20, 2007 | 10:09 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default Valve Seals
Do you actually mean valve "guides"??? Or, are you refering to resurfacing the valve "seat"????
In any case, get a service manual, and it will tell you what all is involved.....
Old May 20, 2007 | 11:49 AM
Default Valve Seals
ummm, i'm not sure. a friend of mine that is really good with working on quads said that my valve seals might need replaced, cuz it smokes a little bit.
Old May 20, 2007 | 02:45 PM
Gimpster's Avatar
Default Valve Seals
Serviced the seals on a 400EX yesterday. There are a few ways to do it. Pressureing up the cylinder and changing them without removing the head, or remove the head and use a valve spring tool to remove the springs. If you have not done this before, I suggest having someone who has, do it or have them help you.
The unit I did smoked when first started. I did find the exhaust seals were not soft, they were baked hard. I pressured up the cylinder after removing the entire valve cover, rocker assembly. I used a tool to compress the valve springs that I built for myself, years ago. Works slick !
----- Gregg -----
Old May 20, 2007 | 11:21 PM
cluby's Avatar
Default Valve Seals
I think that replacing valve seal is more of a CAR deal, these motor for the most part don't have problems in that area. Worn rings and bad valves are more likely
Old May 20, 2007 | 11:52 PM
Gimpster's Avatar
Default Valve Seals
Good point.
Notice I said that the 400 I replaced the seals on smoked when started and then cleared up.
I was brought this unit last year with a lunched cam and head. They came up with a head off e-bay. I talked them into re-ringing the unit but they did not want me to go through the e-bay head as they were told it was good. I made a note the seals were bad on the work order. Guess what ? It is back for seals, and still no head rebuild. Oh well, the start-up smoking went away.
----- G -----
exmotocrosser
Sep 13, 2019 06:12 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
