DS 650 front hubs stuck?
Old May 21, 2007 | 03:44 PM
Todem's Avatar
Default DS 650 front hubs stuck?
[img]i/expressions/face-icon-small-confused.gif[/img]Hello,
I'm pretty new to this site and new to the DS family. I purchased a 2000 model about a month ago and I love it! I need to change the front wheel bearings but when I removed the tires, king nut, and caliper, the hubs do not slide off. I tried tapping the back of the hub a bit but didn't want to wack anything too hard for fear of bending something. How do these come off? Do they need to be pressed off or am I just a whimp? I tried to take off both sides and they are not moving. Any help would be greatly appreciated. Gotta get her done before this weekend.
Old May 21, 2007 | 07:46 PM
DuneRider650's Avatar
I ride a little here and there......
Be harder on them....they just slide off.
Old May 21, 2007 | 09:17 PM
busmechanic's Avatar
do have any type off "puller" ? or try getting a pry bar behind the hub just to break them loose.
Old May 21, 2007 | 09:28 PM
DStroyer's Avatar
There is an o-ring just on the inside of the hub on the spindle. Spray a dab of wd in there and pull, it will slide right over.
Gary
Old May 22, 2007 | 10:32 AM
Todem's Avatar
Ok, I'll try the trick witht the WD. I did try to use a pully puller but it didn't seem to help. I also tried a steering wheel puller but theat was too small. I will try the pry bar method as well. Thanks for all your input
Justin
Old May 22, 2007 | 11:27 AM
bombrider04's Avatar
They should be able to come off pretty easily just takes a little bit of effort...If you can't get them off and have to resort to air tools then I would, but that is only if you tried everything else because you might indent the hubs.
Old May 23, 2007 | 12:28 PM
Todem's Avatar
Got them off last night. Sprayed lube inside and got a bigger puller and they came right off.
[img]i/expressions/face-icon-small-happy.gif[/img]Thank you guys very much for your help.
Old May 24, 2007 | 11:18 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
When installing I would put antisieze on the hub splines next time they will slide rite off.
Old May 24, 2007 | 11:42 AM
Todem's Avatar
Ok I'll do that. Would axle grease be ok?
scram5050
Aug 30, 2024 01:39 PM
heath legg
Jul 24, 2015 01:01 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tporath
Jul 11, 2015 12:31 PM
