Open air box
Old May 21, 2007 | 04:07 PM
antcomo's Avatar
Default Open air box
has any one had a problem with installing an open air box (pro design) filter in a raptor 660, and having to jet the carbs?.. i put the new filter in took off the lid and the bike bogs out on top end like 3/4 of the throttle open. i had a banshee and installed the same mod but never had to jett ?
Old May 21, 2007 | 04:20 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
If you let more air in you must rejett, or risk running lean and burning it up. You atleast need to bump up your main jet a few sizes.
Old May 21, 2007 | 04:21 PM
ctateusa1's Avatar
you definetly need to get a dynojet jet kit(pretty good instructions included.)
Old May 21, 2007 | 04:22 PM
ctateusa1's Avatar
Oh yhea if you are going to put a pipe on the raptor then I would do it before you rejet that way it will cut down on the amount of times that you will need to rejet the carb.
Old May 21, 2007 | 04:34 PM
antcomo's Avatar
thank you for your help whats a good jet kit?.. also im looking to change my cdi any thoughts or sugestions on that?.
Old May 21, 2007 | 08:51 PM
TrailxRider's Avatar
It's jetting. Your main jet.
Old May 22, 2007 | 10:22 AM
ctateusa1's Avatar
I would look into the Dynojet kit due to it coming with instructions and a larger selection of jets to tune with.
Old May 22, 2007 | 10:48 AM
SickSixtyRider's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: antcomo
has any one had a problem with installing an open air box (pro design) filter in a raptor 660, and having to jet the carbs?.. i put the new filter in took off the lid and the bike bogs out on top end like 3/4 of the throttle open. i had a banshee and installed the same mod but never had to jett ?</end quote></div>
I just installed one and I put in 160 and 165 mains from the stock 140 and 145 mains. It runs perfect.
ReconBayou
Oct 31, 2022 05:37 PM
Hack714
Sep 26, 2015 08:11 AM
black_thunder
Sep 22, 2015 07:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Hack714
Sep 20, 2015 05:54 PM
