Compression test - HELP!
Old May 21, 2007 | 11:41 PM
dbenavidez's Avatar
Default Compression test - HELP!
I have a 2005 Trailblazer that just quit running. I have tried several things to see if I can get it running again, but it has become clear I need to do a compression test. How exactly do I do that? Keep in mind I am a novice. Thanks, Dario
Old May 22, 2007 | 12:00 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I sent you a P.M
I just can't tell you what the compression should be on that quad...............I don't know!!!!!......Someone here should reply and tell you what compression numbers you "SHOULD" have on the gauge!!....Good Luck.......Caper........
Old May 22, 2007 | 12:01 AM
hikuntryslim's Avatar
you will need a compression gauge , and it should read between 120-125 pounds for the trailblazer . check compression with ignition off and the throttle open . if compression reads low , put two teaspoonsof oil down the sparkplug hole and recheck . if compression improves a bunch ...get out the wrenches .
Old May 22, 2007 | 07:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
anything below 100 psi time to bebuild.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Steeldon
Sep 9, 2015 09:38 AM
awer1968
Sep 8, 2015 11:02 AM
