outy 800
Old May 23, 2007 | 12:28 AM
kolbrider's Avatar
Default outy 800
I was told by my uncle that the outy's had a good everything setup except for riding through water. He also said that you have to make your own home made snorkle system. If i ride in alot of water would this be a good idea to install one or would it be a waste of my time? And if anybody has installed one how ong does it take?
Old May 23, 2007 | 12:37 AM
Steveo10's Avatar
Default outy 800
It will go deep in water as long as your CVT doesnt leak. Its worth the hassle to snorkel the outtie. Do a search on here
Old May 23, 2007 | 04:42 PM
Dufrane's Avatar
Default outy 800
here's the scoop.....there good in water up to about the side or top of motor.as long as your just putting around. if you go splashing water can(and will) splash into the air breather and the cvt intake. so yes your uncle is right snorkle it. i used flexible sump pump hose for my 500 and my dad liked it so much did his 800 when it came back from 10 hour service.
Old May 23, 2007 | 11:06 PM
kolbrider's Avatar
Default outy 800
Ok so what wil actually happen if water does get in it like if i am going to be riding hardcore water, is it a must to get the snorkle kit?
THANX
Old May 24, 2007 | 12:41 AM
Dufrane's Avatar
Default outy 800
if you get in water over the front fenders you will suck water into the cvt case and the air intake...then your belt will slip....i've tried to put up pics on my page today to show you......also go to your private message i left you a message
Old May 24, 2007 | 09:34 PM
2005buck650's Avatar
Default outy 800
Very much worth it. It gives you a piece of mind when creek riding or dipping down in that mudhole you just dont know exactly how deep it is.
Here is a trail friendly snorkel.
Here is a "Lets find the deep shiznit" snorkel
Here is a picture after a "deep shiznit find"
CVT
Old May 25, 2007 | 02:05 AM
Steveo10's Avatar
Default outy 800
Its a good idea of having the CVT intake below the air intake... So if you get water in CVT you will stop and will not go into deeper water and sink from your tires spinning unless you are in muskeg
Customfabandweld
Jun 9, 2006 01:48 AM
MITTY26
May 26, 2006 01:49 AM
cc1999
Mar 4, 2006 12:45 AM
rfwlll
Jan 29, 2006 09:58 AM
