polaris 500 4x4
Old May 31, 2007 | 11:34 PM
TOYMAN30101's Avatar
Default polaris 500 4x4
my 2003 polaris scrambler 500 has a bad engine hesitation problem. under a load or giving it alot of throttle makes it hesitate. butt in reverse with the over ride switch is pressed is does not hesitate. sometimes it wont even pull up a hill because of the hesitation problem. any help woud be appreciated. this atv is stock and has had the valves set to polaris specs and the spark plug has been replaced with a new and it still has not fixed the problem.
Old May 31, 2007 | 11:38 PM
scramblerXrated's Avatar
have you tried to push the button while you try and pull up a hill? there might be an electronic issue here.
X
Old May 31, 2007 | 11:45 PM
thats a good idea. havent tried that butt i will. thanks for the advice. i know when i put it in reverse and press the over ride switch it does not hesitate. thanks again
Old Jun 1, 2007 | 07:41 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like the overirde rev limited is messing up.
Old Jun 2, 2007 | 12:40 AM
do u know how to fix it. is it easy as replacing the over ride switch. appreciate the help in advance.
Old Jun 2, 2007 | 08:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure on your bike if it has a trans. switch which tells its in reverse or not but that could be part of the problem as well. i thought you ment to bypass the override switch. sorry my brain cramp.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
