REBUILT BANSHEE WILL ONLY IDLE
Old Jun 3, 2007 | 11:53 AM
CHRISTALLMAN's Avatar
Default REBUILT BANSHEE WILL ONLY IDLE
DOES ANYONE KNOW ABOUT THE TORS SYSTEM ON A BANSHEE?? MY BANSHEE I BOUGHT WAS WORE OUT SO IREBUILT THE MOTOR AND EVERY NUT AND BOLT,BUT WHEN I START IT,IT WILL ONLY IDLE,STALLS WHEN GIVING IT ANY GAS.WHEN I WIGGLE THE THROTTLE SWITCH UNDER THE THROTTLE COVER IT IDLES A LITTLE HIGHER BUT STILL CANT GAS IT.IT RAN ROUGH BEFORE I TORE IT APART BUT YOU COULD RIDE IT EVERYDAY. SOMONE TOLD ME OF A BYPASS KIT FOR THIS SYSTEM??ANY HELP WOULD BE GREAT,THANKS
Old Jun 4, 2007 | 02:12 AM
rruser's Avatar
On a side note, also check your carb slides. They are keyed in such a way that will make them fit backwords if you swap them between carbs. The airbox side of the carb should have the notch in the slide.
Old Jun 6, 2007 | 08:57 AM
fastquad02blaster's Avatar
I'm pretty sure it's your TORS stuff doing it. Somebody on here was talking about bypass for a blaster, but I'm pretty sure it's the same thing. There's just two carbs instead of one. Start a new post about Tors bypass and you'll get something.
Old Jun 6, 2007 | 09:27 AM
I found some notes on the blaster tors bypass that somebody posted on here a while back. They said to just cut the wire leading to the top of the carb. and to cut the wire leading to the switch. I'm not sure if there's one wire or to on both of those. I'd guess to say that there's two if they're switches though. If that's the case you might have to twist them together and try that.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
Jason Richards
Sep 4, 2015 06:17 PM
