2004 big bear carb adjustment help
Old Jun 4, 2007 | 10:33 AM
albigbear's Avatar
Default 2004 big bear carb adjustment help
I need to adjust my rich/lean mixture on carb, what is the screw setting? I have it almost 2 turns out now, seems to be running rich. The screw that I adjust is on the bottom of the carb, is this the right screw? Also, what is the procedure on adjusting the valves.
Old Jun 4, 2007 | 10:51 AM
MrDumass's Avatar
Super Quad Patrol
Athens Archery Field Staff
Best lunch hour ever!
<div class="FTQUOTE"><begin quote>Originally posted by: albigbear
I need to adjust my rich/lean mixture on carb, what is the screw setting? I have it almost 2 turns out now, seems to be running rich. The screw that I adjust is on the bottom of the carb, is this the right screw? Also, what is the procedure on adjusting the valves.</end quote></div>
Why do you need to adjust it? Did you add something aftermarket? The screw is in the bottom and its tough to reach without one of those stubby straight blades. Stock should be right at 2.... 2 /1/2 turns out. I think I have mine set at about 3 1/2.
As far as the valves go....I'd take it to someone.
Old Jun 4, 2007 | 10:58 AM
albigbear's Avatar
Thanks, I took the carb apart, cleaned it, was idling rough. I adjusted the screw to where it was before, but seems like it was running rich before, so was just curious of the adjustment.
neilbedwell
Nov 10, 2018 11:02 AM
Ty Speece
Jul 2, 2015 04:59 PM
regiedina@gmail.com
Jun 20, 2015 03:19 PM
robj
Jun 15, 2015 08:45 PM
Joe04785
Jun 15, 2015 03:12 AM
