Does an enclosed Ranger need a heater?
Old Jun 6, 2007 | 12:42 AM
tyler711's Avatar
Default Does an enclosed Ranger need a heater?
WE just got a ranger xp with a full cab. With the cab on, it can get really hot in there once the engine warms up.
I know polaris makes heaters, but I was wondering, in the winter, is the thin cab plastic enough to keep the heat in? Or does it dissipate right out? I know that if you pop off the heat shield under the middle seat, the heat (and the noise) just start to pour into the cab.
Tyler
Old Jun 6, 2007 | 12:52 AM
buckaroo50's Avatar
I guess it all depends how cold it is and how fast you are driving. Just like a car sometimes you need a lot of heat other times you don't. If you had a heater and didn't need it then you don't use it. If you don't have a heater and need more heat then I guess you get cold.
Old Jun 6, 2007 | 11:37 PM
tyler711's Avatar
Well, winters here in maine are cold. All I'm really asking is whether or not the engine alone supplies enough heat to make a noticeable difference in the temperature inside the cab in the winter. I know that now, when it's warm with the cab on, it gets steamy hot inside. But that's with no wind chill cooling the outside of the cab.
Does anyone have any experience using a ranger in the winter?
Thanks
Tyler
Old Jun 7, 2007 | 12:05 AM
LTZ's Avatar
LTZ
I don't have a cab on mine and I live in Ca so I may not be much help but I have been in mine when it was 11* and it was cold! We had plenty of cold weather gear on and it was bearable but it could have been better. I would think that with a cab it would be decent but the heater would make it that much better.
Old Jun 10, 2007 | 12:30 PM
ADQX2's Avatar
i'll tell you i've installed 2-3 heaters up here in alaska & they are not worth the headache , you have to make sure there is absolutely no air in the system or the heater only works sometimes & the heater only works when you are above 3000 rpm's (it's the way the system is designed , full of flaws) & for $485 bucks it just doesn't seem to work all that well! invest in an electric heater that runs off the 12 volt (cigerette )port & bundle up a little more
Old Jun 10, 2007 | 12:49 PM
drlang's Avatar
Tyler711, HHHMMM I've seen that name before. Doc
Old Jun 11, 2007 | 11:26 PM
tyler711's Avatar
Alright, thanks guys.
Doc!! What's up? Hehe maybe i'll see you at the 'house tonight?
Old Jun 11, 2007 | 11:38 PM
drlang's Avatar
Well I certainly don't want to take up any of your time. Remember the whole display issue I had? I didn't reload the drivers properly, DUH
badgerboy1
Sep 26, 2017 06:11 PM
shimanok2
Jan 29, 2016 07:37 PM
WilliamBos
Sep 22, 2015 04:07 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
