Front End Play
Old Jun 11, 2007 | 10:35 PM
Polaris-Nut's Avatar
Default Front End Play
Hello All I just replaced my Inner & Outer tierod ends and I still have a little play back and forth as well as up & down when I pull up on the handles bars when I had someone turn the handle bars back and forth I noticed that at the very bottom of the steering shaft where there is a big nut with a cotter pin in it there is some play what could it be or is there a bearing or bushing down there that can be replaced if so does anyone know how to do it thank you
Old Jun 11, 2007 | 11:46 PM
Krammer220's Avatar
Yeah... The lower "plastic" bearing is known to go bad fairly quickly, Don't know what year your quad is but they were improved on more recent models..... Check out this aluminum aftermarket replacement....
This is where I got mine....If you go this route you'll need to drill out the two rivet holes a little to fit the larger bolts that come w/this....A long drill bit helps!!
http://www.aaenperformance.com/Acces_P3.asp
Or...
http://www.rittercycle.com/polaris.htm
Old Jun 11, 2007 | 11:56 PM
buckaroo50's Avatar
Yes there is a bearing down there.
You may be able to just disassemble the lower end of the steering column (tie-rods, bearing flange etc) and get it out that way. If not then you will have to also disassemble the top and remove the steering post or at least loosen it.
Old Jun 11, 2007 | 11:57 PM
Krammer220 Thank you for your help will check that out my atv is a 1999 Magnum 500
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
carolinabomb
Jul 26, 2015 08:40 AM
carolinabomb
CAN-AM (BRP) Ask an Expert!
Jul 25, 2015 08:59 PM
tporath
Jul 11, 2015 12:31 PM
