1994 Sportsman 400 / Reverse Override
Old Jun 7, 2007 | 01:12 AM
WatchingWolf's Avatar
Default 1994 Sportsman 400 / Reverse Override
Rev limiter finally went out. I'm just gonna go with the bypass, but after two hours of searching the forum, I have yet to find out how. First off, let me say this,
1994
Please don't post the link to the post with the relay and the four chunks of wire. I don't have a digital dash, a yellow button or back up lights. I do have an override button, a yellow light with an R in the middle that comes on when you push the button and a gray wire w/ a white stripe & a purple wire coming off the override switch.
Am I correct in these facts? Cut the gray/white wire, tape end of wire leading to the switch, attach other to any red/w white stripe.
Some posts have said to cut the purple wire, why? Could I use the taped end of the gray/white to engage a horn relay if the purple wire is left uncut, or do I have to to cut it, tape the "hot" end, and find another power source to route through the switch side of the purple wire? The only problem I can see is that the R light may come on when I blow the horn. I can live with that.
Old Jun 7, 2007 | 07:59 AM
ftwflh's Avatar
Find the rev limiter box and unplug the black wire
Old Jun 7, 2007 | 09:04 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats sounds way to easy lol. sounds like he wants to use his button as a horn as well.
Old Jun 9, 2007 | 12:41 AM
Unhooked the black wire. Still have to hold the button for four wheel drive in reverse.
Old Jun 9, 2007 | 07:57 AM
ftwflh's Avatar
That is the way I bypass all my bikes when the rev limiter messes up.I dont mind holding in the button for an easy fix.
Old Jun 9, 2007 | 08:14 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the newer ones you have to slice the 2 wires together to by pass it and still have the awd to work.
Old Jun 9, 2007 | 07:23 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
the newer ones you have to slice the 2 wires together to by pass it and still have the awd to work.</end quote></div>
Does it look like a tight wad like me has anything that new to mess with[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jun 9, 2007 | 07:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hey bro, we all have to be tight wads in this day and age w/ the cost of fuel and everything esle right. lol.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 9, 2007 | 07:38 PM
ftwflh's Avatar
You got it!Just went riding for 2 hrs and cost me almost $7.That is why I try to tell these guys the cheapest was to fix these things.
I been there done that to these things and found out the hard way that you dont need to spend a ton keeping them running or modded them to run better.
BTW I miss my old 96 400 Sportsman
Old Jun 10, 2007 | 11:26 AM
drlang's Avatar
Tight wad, that's just called having children. Man - O - man, they suck the cash right out of you!!!
Stirling
Aug 11, 2015 07:23 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Scottma518
Jul 10, 2015 12:42 AM
