atv has no spark
Old Jun 13, 2007 | 08:59 PM
hking04's Avatar
Default atv has no spark
I have a 2006 eagle bobkat 110 atv that has no spark,I changed the cdi box,coil,magneto,and wiring harness and still have no spark. I also made sure that the tether switch was functioning properley, does anyone have a clue?
Old Jun 13, 2007 | 10:42 PM
buckaroo50's Avatar
Best that I can do for you - hope it helps
Problem: Spark absent or weak
Condition Remedy
1. Ignition coil defective 1. Replace ignition coil
2. Spark plug defective 2. Replace plug
3. Magneto defective 3. Replace magneto
4. CDI unit defective 4. Replace CDI unit
5. Pick-up coil defective 5. Replace pick-up coil
Old Jun 14, 2007 | 11:44 AM
oneOone's Avatar
does the battery have a good charge? if so have you hooked up a mulit-meter to verify that you are getting power the the listed componets, I would start at the battery and work your way to the spark plug, it could be a damaged wire. is the starter engaging?
Old Jun 14, 2007 | 05:31 PM
hking04's Avatar
I tested everything with a volt meter, everything seems to read correctly,then again I don't know a lot about testing with the meter or what the readings mean but when I check the wires coming out of all the mager components the meter changes.
Old Jun 16, 2007 | 10:33 AM
davepctech's Avatar
I have a 150cc Chinese made bike that the stator went out on it. I've heard others say the same thing so that could be the culprit.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
