2001 Rancher350 ES Unable to get it in Reverse
Old Jun 14, 2007 | 11:04 PM
FUBAR1993's Avatar
Default 2001 Rancher350 ES Unable to get it in Reverse
Went riding on my Honda Rancher 350 ES today was on a steep incline trying to back out, cause going forward wasn't an option. I tried to put it in reverse and it wouldn't engage it had been working fine previously that day and it just up and stopped working at a horrible moment. All the other gears work perfectly it just wont go below neutral and into reverse. If any can offer some advice or insight on what the prob could be it would be a huge help.
thanks
Old Jun 14, 2007 | 11:37 PM
FUBAR1993's Avatar
It's the all time 4 wheel drive version
Old Jun 15, 2007 | 07:09 AM
HondaMechanic's Avatar
Either the reverse lock system cable needs adjusting , or the reverse wire came off the reverse switch which is beside the reverse lock system lever at the bottom rear of the engine .. Probably it is the wire & boot came off the reverse switch..
Old Jun 17, 2007 | 01:54 AM
FUBAR1993's Avatar
Yeah the wire came off found it after lifting it up and looking thnx a bunch
Old Jul 30, 2007 | 09:15 PM
Uborntoride's Avatar
Hey today I'm having the same problem with my 2003 Honda 350ES. Exept I'm not much of a mechanic! I just know how to ride. So can you make things a little clearer for me as to were to find this reverse switch please.
Thank you;
JO[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jul 30, 2007 | 10:35 PM
at the rear bottom of the engine .. You will see the reverse lock-out lever & the reverse lock-out cable .. Right beside it you will see the reverse switch the reverse switch wire should be plugged into it , you will see the wire it has a bubber boot on it
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
r1pilot83
Sep 27, 2015 07:38 PM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
