EPIC gone soon
Old Jun 15, 2007 | 09:21 AM
CALDS650's Avatar
Default EPIC gone soon
Soon I will have replaced all the EPIC junk off my DS. I will be able too ride safe and adjust my chain again soon.
Old Jun 15, 2007 | 12:46 PM
TPR's Avatar
TPR
The Champ
LOL, good for you. Then maybe your sad journey to try and discredit them will come to an end.
I feel bad for you, I really do. Your revisionist history is an amazing thing to behold as you and I both know the truth behind all your "turmoil."
Do yourself and all of us a favor, move on with your life. Please put on any and all products you feel are worth your money and use. Talk them up till you're blue in the face, because the sad truth is that nothing you say really matters to Epic or anyone associated with them.
I only respond to your continued, pathetic rantings because I know the truths you fail to divulge, you're bitter because after time and again it was found that error's you made were the root cause for your issues, but since we are talking integrity here, that's just somthing I feel you will never be able to manage.
Take care Outlaw Bill....despite all your rantings, it would appear that Epic is flying sky high right now, and apparently you did nothing to negate that.....[img]i/expressions/face-icon-small-happy.gif[/img]
TPR
TPR
Old Jun 15, 2007 | 01:52 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
I could not have said it better TBR, My epic A-arms are the best A-arms I have ever had and the only gripe would be not being able to get new ones for my friends it is hard to find them with all the racing thay do you cant get ahold of them, so that tells you CALDS650 you should have a great resale value[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 15, 2007 | 08:39 PM
CALDS650's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: pipelayer
I could not have said it better TBR, My epic A-arms are the best A-arms I have ever had and the only gripe would be not being able to get new ones for my friends it is hard to find them with all the racing thay do you cant get ahold of them, so that tells you CALDS650 you should have a great resale value[IMG][/IMG]</end quote></div>
sorry I will not resell a un-safe product ps check the nuts on the ball joints they will work lose on you
Old Jun 15, 2007 | 09:05 PM
CALDS650's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TPR
Take care Outlaw Bill....despite all your rantings, it would appear that Epic is flying sky high right now, and apparently you did nothing to negate that.....[img][/img]
TPR
TPR</end quote></div>
I will never go away if some body ask what about EPIC I will say they make great product if you are a pro rider. They have very poor customer service and what is there phone # this week? They may have improved but I will not trust them again.
Old Jun 16, 2007 | 12:24 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Wow did i miss something why you so upset bill.whats up guy's i know bill is a great guy.I know tim is a great guy so what gives wheres the stoty posted
Old Jun 16, 2007 | 12:56 AM
ERBEDS650's Avatar
Its not just EPIC, seems there is a riff in customer service in the ATV A ARM Chassis, Swing Arm aftermarket industry, DSnutz&lt;--2 Big nightmares, I bought some A arms from Burgard and they sent the wrong Tie rods, been waiting over a month, again im not understanding there customer service mentality? I understand its not all of these guys but more of a few rotten apples start to leave a bitter taste
Old Jun 16, 2007 | 01:05 AM
AZSAND's Avatar
Jeff @ metal tech he could careless if any of you ever use him but if you call him and order something it will be done as said when said and quality is unmatched he has been in buiness for years and will be there when the bombs are all gone.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jun 16, 2007 | 01:09 AM
ERBEDS650's Avatar
Az, cool your jets , I just wrote there are a few turds in the pool is all
<div class="FTQUOTE"><begin quote>Originally posted by: AZSAND
Jeff @ metal tech he could careless if any of you ever use him but if you call him and order something it will be done as said when said and quality is unmatched he has been in buiness for years and will be there when the bombs are all gone.[img][/img]</end quote></div>
Old Jun 16, 2007 | 09:33 AM
CALDS650's Avatar
Wow did i miss something why you so upset bill.whats up guy's i know bill is a great guy.I know tim is a great guy so what gives wheres the stoty posted</end quote></div>
First off I had problems with a new swing Arm. there is a difference in the rear shocks 04 and 00 but I got around that. Then I could not get a socket on one side of the lower shock mount so they ground off the powder coating and enlarge the hole, Then I could not get the get the brake caliper mount on because the bearing housing was to wide I called they said I was doing soothing wrong. I take it too them and show them, the fix was too grind down the housing with a new bearing carrier new bearings just greased and, seals installed on the swing arm.. They due not even cover up the new bearing and just grind down the housing and fill up the new bearing with metal particles and tell nothing is wrong and it should be fine now. Then I had the R/F front wheel fall off out in the dunes it took me 4 hours to get out. This is part my fault for not checking the nuts on the ball joints but if EPIC had used castle nuts instead of nylock. I would not have had this problem. EPIC answer is using more lock tight.
