2004 Outlander 330 No Start - Fuel Issue
Old Jun 15, 2007 | 01:59 PM
Eliminator's Avatar
Default 2004 Outlander 330 No Start - Fuel Issue
I am new to this forum but I have been reading it for quite a while. I thought I would share this experience in the hopes of helping out others.
Yesterday I jumped on my Outy, set the choke, and cranked it over. It started up as usual but as I eased the choke off it stalled. I reset the choke again and restarted and the Outy ran for about 20 seconds and died. It would not restart. It acted like it was out of gas. I checked the fuel tank (it was 1/2 full) but switched it to reserve anyway. Still no start.
I pulled the spark plug and it was dry but spark was present. I noticed that the fuel line from the fuel selector switch to the fuel pump was slightly cracked and made a note that I should replace it soon. I decided to check the fuel pump and that's when I noticed the fuel line where I found the cracks earlier had very large and deep cracks at the fuel pump connection. Removing the hose identified a crack thru to the inside of the hose which caused the pump to just suck air. No leaking occured since this is a suction line and the pump sits higher than the fuel tank level.
I replaced the 1/4" fuel line with a new piece and the Outy started after a few long cranks as the pump needed to refill the hoses and the fuel bowl. It now restarts just fine.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
