Phoenix transmission
Old Jun 18, 2007 | 04:21 PM
twister500's Avatar
Default Phoenix transmission
I have an 05 Phoenix and it just started to jump out of gear when going foward.
You dont have to get on it hard it just jumps out. I adjusted the linkage and also changed the fluid. (yes the agl) and it still does it. I pulled the linkage at the trans and the same thing happens. Any one have this happen?[img]i/expressions/beer.gif[/img]
Old Jun 20, 2007 | 10:47 PM
twister500's Avatar
Any one?
Old Jun 21, 2007 | 09:56 AM
Zoomer99's Avatar
Here is a link to a service bulletin for the 05 Phoenix about replacing a detent spring & ball in the shifter at the transmission. It sayes its to correct "hard shifting" issues. Not sure if this would cause it to jump out of gear, but its worth checking out.
https://www.polarisdealers.com/servw...cement.pdf.pdf
Hope this helps,
Zoomer
Old Jul 16, 2007 | 08:14 AM
twister500's Avatar
I put in the new detent spring and ball still the same anyon have another thought?
Old Aug 7, 2007 | 09:49 PM
twister500's Avatar
OK here we go. It needs 3 gears in the trans and most likely a shift fork. After checking around for a while I found a dealer in PA. who told me what to look for and its it.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
