450r or Rubicon
Old Jun 18, 2007 | 10:19 PM
ridered28's Avatar
Default 450r or Rubicon
Hey guys im getting a new quad this week. I have a 400ex but i need more speed but i also like utilitys. Im either going to get a 450r or a rubicon. Help me out please.
05 400ex
fmf powercore 4
ac nerfs
07 Honda Rancher 420
Old Jun 19, 2007 | 02:46 AM
crummie's Avatar
Well since you already have a sport fourwheeler I would go rubicon. I consider the rubicon to be more utility, so if you like sportier bikes you might want to consider the rincon.
Old Jun 19, 2007 | 12:20 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Hi ridered28 welcome to the forum.
You already have a sport and an utility I see. I guess i just matters what you want to be doing with your new one and if your are adding or replacing your old. The 400EX is the best trail quad you can get (IMO). If you go with a 450R you won't like that thing during trail riding. 450R's are to high geared and will cause alot of clutch work. If you ride more open trails the 450R will be good. They are powerful and have a good feel to them. Now the utility would be best for more harsh terrain where the 450R would not even go. Another choice is to mod out one of the wheelers you have, a 426 big bore with a cam will really wake that 400EX up. Basically comes down to where you want to ride with your new wheeler.
Old Jun 20, 2007 | 02:31 PM
ridered28's Avatar
Im going to get the rubicon but what can i do to my 400ex to make it fast except for going into the engine. right now i have a pipe so im probably going to change the headers.
Old Jun 20, 2007 | 02:38 PM
Koopa's Avatar
You can remove the airbox lid depending on what type of riding you do. Be sure to re jet accordingly. Re-jetting the carb is a must when adding pipes or modifying airbox. Besides that not sure what I'd do if you don't want to get into the engine. Cam maybe, if your willing.
Old Jun 20, 2007 | 02:55 PM
ridered28's Avatar
I was thinking K&N air filter. Rev box, Hot cams stage 2 and headers. I can hit like low 70s now i wanna get into the 80s?
Old Jun 20, 2007 | 03:05 PM
Fulltiltrider's Avatar
Get someone to port it. Go with web cams they are much better. Try to find a 40 or 42mm lectron carb, and a 11:1 JE piston. Dont worry about a big bore kit they dont make that much more power without the other mods + the added weight of the piston causes your motor not to balanced properly and can cause motor destroying vibrations unless you have the piston grammed out. Then you will keep up with anyone, and probably cost less than 700.
Koopa's Avatar
I dislike K&N. They need a prefilter for the filter for goodness sake. I'd stick with Uni or some other foam filter. Also, Hotcam stage 1. Stage 2 will be good with stock compression. now that i think about it, I'm not sure if a stage 1 is recommended with stock compression. But, if your just wanting top speed change your sprockets. Put like a 16 or 17 tooth front sprocket and some 22" tires. You'll get some top speed.
Old Jun 20, 2007 | 05:14 PM
A 17 tooth sprocket and 22 in tires you probably wont pull 4th let alone 5th on a near stock 400
Old Jun 20, 2007 | 05:21 PM
Koopa's Avatar
Just Sarcasm Fulltiltrider. I'll try make it more pronounced next time. Guess I probably should so nobody will take that advice.
