300ex spark plug
Old Jun 19, 2007 | 06:50 PM
Matt1980's Avatar
Default 300ex spark plug
I went to Ohio cycle worx and needed a spark plug for my 300ex and wanted to know if NGK DPR7EA-9 will work because this one is not in my Clymer manual
Old Jun 19, 2007 | 09:06 PM
plugguy's Avatar
Hey there,Check out NKG CATALOG on line.
Go to ATV,and follow the steps.
They'll give you the right # for the oe plug and show you a photo of it.
Happy Motoring[img]i/expressions/face-icon-small-smile.gif[/img]
<div class="FTQUOTE"><begin quote>Originally posted by: Matt1980
I went to Ohio cycle worx and needed a spark plug for my 300ex and wanted to know if NGK DPR7EA-9 will work because this one is not in my Clymer manual</end quote></div>
Old Jun 20, 2007 | 09:51 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
My experience with the 300EX is that it is very sensitive to having a plug of the right heat range! Find out what the stock plug is and try it, then try a half range cooler in summer and hotter in winter. Maybe even a whole range if you live where it is extremely hot or extremely cold. You may be able to fine tune your performance.....
Old Jun 20, 2007 | 10:20 AM
Williebee's Avatar
I have a Haynes manual theTRX 300EX Standard NGK DR8ES-L or ND X24ESR-U Cold climite(below 41 degrees F...............NGK DR7ES or ND X22ESR-U Extended High Speed Riding.......NGK DR8ES or ND X27ESR-U TRX400 EX - Standard..................NGK DPR8Z or ND X24GPR-U Extended High Speed riding..............NGK DPR9Z or ND X27ESR-U GAP.........0.6 to 0.7mm (0.24 to0.28 inch ) Clutch lever freeplay............10 to 20mm (3/8 to3/4 ) I got this info from a Haynes 2318 Manual Covers HONDA TRX 300EX & TRX 400EX ATVs 1993 thru 1999 Year models 282cc to 397cc Ownwers Workshop Manual I hope this is of some help...........................williebee !
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
