Sport Quads Discussions on sport quads.
Dealers? What to do with New Yamaha 700r in Crate!
Old Jun 20, 2007 | 06:25 AM
UKPaisley's Avatar
Default Dealers? What to do with New Yamaha 700r in Crate!
OK my Yamaha 700R is now at home where I work in Angola. Basically there are no dealers with any mechanical knowledge I trust here so what's the best method of getting started and the checks that should be performed. If the battery is dry I know I need to add the acid, leave for at least 5 hours and then charge slowly for another 5 hours , stuff like that. Will check fluids, but is the oil from Yamaha ok or change out asap.
Regards DP
Old Jun 20, 2007 | 10:52 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Yamalube isn't bad oil, if you can get it where you are. No synthetic until after break-in! Yamalube has a petroleum base, but with synthetic additives. Not sure it is suitable for break-in (????). The factory might put in some kind of special pure petroleum break-in oil (????).
I always do an oil and oil filter change after 1 hour of break-in riding, to get the metal shavings out of the engine first thing.
Read this before you even start the engine for the first time: http://www.mototuneusa.com/break_in_secrets.htm
I break-in doing hillclimbs. Ride it hard and fast up a steep hill, then come down it under heavy compression braking. I do that three times, then park it and cool it off completely. Next day I do the same thing. I do that for several days, then just ride it normally, but constantly varying the speed.
Old Jun 21, 2007 | 04:18 AM
UKPaisley's Avatar
Very controversial !, I intend to run in using a similar way on the beach, as I am nearly 40 I have been around bikes and cars since I was 8 or 9, the more responsive bikes have always been the ones that have been "Thrashed from the start"
Anyway just pumped the tyres up, and fit the wheels , skid plates, handle bars, ignition heel guards, front shocks, ...... the list goes on and on I recon I have about 5 hours work to put it together.
Old Jun 21, 2007 | 09:32 AM
Red Rider
On the beach, I would do hard acceleration followed by hard deceleration, with lots of compression braking (downshift!). The engine braking compression will help wear in the rings as well.
Old Jun 22, 2007 | 04:22 PM
mdebuck's Avatar
change the oil out after the 1st month of riding
Old Jul 4, 2007 | 09:10 PM
crazy1291's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mdebuck
change the oil out after the 1st month of riding</end quote></div>
after one month???? how much riding do you do? i had to change my oil the 3rd or 4th day after i got mine- as soon as i got home i just rode
Old Jul 5, 2007 | 07:41 PM
mdebuck's Avatar
i do a lot of riding at least every 2 days i guess everyone has their own opinions on changing the oil
Old Jul 6, 2007 | 04:07 PM
crazy1291's Avatar
that sucks you only get to go riding 3 times a week, i like where i live- lots/enough trails to go on, and 2 huge tracks 20 minutes drive away, could go riding every day all day almost
i changed the oil for the break in after 8 or 10 hours
Old Jul 6, 2007 | 10:25 PM
mdebuck's Avatar
at my house we only have 4 acres and our trails seem to get boring.
Aug 21, 2015 01:23 PM
MONKY LONDON
Aug 11, 2015 08:39 PM
RedRancher
Aug 10, 2015 01:28 PM
Bratman2
Jul 25, 2015 07:16 PM
