Best mods for the buck?
Old Dec 29, 2000 | 02:08 PM
HondaEX400's Avatar
I have a 2000 Honda 400EX and have already put a 14 tooth counter sprocket, and a motion pro twist throttle. What can i do to show significant power increase for about 100-150$?
Old Dec 29, 2000 | 02:17 PM
3o0eXpAuL's Avatar
maybe a used pipe.
Old Dec 29, 2000 | 02:20 PM
ModdedX's Avatar
K&N Filter - $40 or so
Splitfire plug
Cams run about $150 or so( not sure on the 400) but then if you cant put it in yourself you would need to pay someone to. And if you got a cam you would also need Valve Springs and Retainers.
Thats about all I can come up with..
Old Dec 29, 2000 | 02:29 PM
Aaron10's Avatar
Simple. Get yourself a JE 11.1 compressoin stock piston.
Old Dec 29, 2000 | 03:12 PM
HondaEX400's Avatar
How much is the piston? I plan on boring it as soon as i get my job, or turn 18 and cash some savings bonds. Where can i get a 11.1 piston and what does it do? I am very new o mechanics.
Old Dec 29, 2000 | 03:25 PM
Skeet697's Avatar
Boring the cylinder is said to make the machine less reliable. also boring means you'll have a bigger piston which means more weight while if you keep stock bore you won't have as much weight. Therefore when you keep stock bore higher RPM's which means more top end. Any ATV magazine will tell you where you could find accessories including a piston. A different piston will higher compression and produce more power.
Old Dec 29, 2000 | 04:07 PM
GrimReaper's Avatar
Call CT Racing and get a lightened Ross Racing piston with 11:1 compression. Just get the stock bore size which would be 85mm. I have this piston in my 400EX and i made a big difference in power.
Old Dec 29, 2000 | 07:14 PM
wheeliedude's Avatar
I heard a K&N Power Kit makes quite a difference. I am puttin one on my bike, and maybe a pipe. not sure yet which one. power kits run @ 130 in the U.S.
Old Jan 3, 2001 | 12:24 AM
tbass2's Avatar
If you get the K&N beware of jetting it right. I put one on my trike and melted a piston cause it wasn't right!
Old Jan 3, 2001 | 12:39 AM
86atc250r's Avatar
Forget the filter and jet kits, they're a waste of time and money.
The best bang for the buck in the $150 range is going to be a high compression piston. Get the stock size unless you have to bore due to cylinder wear/damage. Then jet the bike in correctly with Keihin jets, they are much cheaper than a "jet kit" and work every bit as well or better.
A JE piston, rings, and wristpin will run you approx $130 and can be ordered from a number of sources including JE themselves. A top end gasket kit will run you approx $25. A Wiseco piston will be cheaper & can be ordered from a number of places as well.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
