gearing on a 400ex
Old Jul 4, 2007 | 03:55 PM
sdm111's Avatar
2 strokes or 4
Default gearing on a 400ex
does anyone know how many teeth are standard on the rear sprocket and if there is an aftermarket sprocket that i can get for better topend? and the same for the front.
Old Jul 4, 2007 | 09:08 PM
muddstudd's Avatar
the front is 15 and the rear is 38 stock, but there are alot of brands to choose from. the smallest rear i've seen is 36 and the biggest is 39, but if you call sidewinder they can custom make you about any size you need. i wouldn't go no higher than a 16 on the front and a 36 on the rear personally.
Old Jul 4, 2007 | 09:41 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Front sprockets are relatively cheap. All the mail order places carry them. I like Renthal. Get one that is one tooth larger...try it out and see what happens. Hope you have enough chain slack!
Rear sprockets are more expensive. Remember, 1 tooth in front = 3 teeth in back. If going up one in front is to much (you lost to much low end), then you can go down 1 or 2 in back as a compromise. If you go down in back, having to little chain length won't be an issue. Might even need to shorten your chain.
Note-If you are changing sprockets, it's usually a good idea to replace the chain too, and start out with everything fresh! Remember, a broken chain can leave you stranded out on the trail.....
Old Jul 6, 2007 | 06:22 PM
dariusld's Avatar
If your quad is newer, then its a 14 front.
Old Jul 7, 2007 | 09:37 AM
sdm111's Avatar
2 strokes or 4
2005
Old Jul 7, 2007 | 02:38 PM
dariusld's Avatar
At rockymountainatv.com you can get a 15 front for about $8. It makes a difference.
Old Jul 9, 2007 | 06:39 PM
sdm111's Avatar
2 strokes or 4
thanks for everyone's help
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Huntingdeer
Aug 23, 2015 12:06 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
