00' blaster will not start
Old Jul 7, 2007 | 10:34 PM
chefmike's Avatar
Default 00' blaster will not start
ok here is my problem; my 00' blaster will not start. here is the whole story. last time it ran was in jan and i forgot to put stableizer in and went to start it last week and it would not start. tried to pull it behind my jeep and it started but died right away. tried to start it with starter fluid nothing. completly cleaned out carb, new plug, cleaned air filter, checked reeds and good, good spark, good fuel flow but did not do a compression test yet. can anyone help me??? thank mike
Old Jul 8, 2007 | 12:33 PM
RickyBobby012889's Avatar
Well the way you say you pulled it off.That makes me beging to thing to rings has spun on the piston...Mine did the same thing i could roll it off but it wont run for a min....My problem was the rigs spun and that will not alow you bike to make compression unless u build it up such as rolling them off....My oil injection stoped up and it wasnt getting oil and thats why they span and seized up on my old piston...CHeck into it and if rebuild is needed go 30 more dollars and gte a set of boyesen power reeds and you will think your on a diffrent bike ....Oh yea dont bore it more than .10 over if you can get by with it..
Old Jul 8, 2007 | 03:42 PM
chefmike's Avatar
thanks ricky
Old Jul 8, 2007 | 05:46 PM
No problem....Be side your foot brake there is a case right beside it with two hoses in it take that plate off and when u take the big line off you will need a reg sized phillips screw driver to plug it up or ur oil will pour out and the unhook the little one from the carb...Pull the oil injector off and take it apart and try to blow though the little line more than likely it will be stopped up spary it out reall good with carb cleaner and then try to blow through it when air flow goes through freely put it back together and that prob will be fixed but i fixed mine and it was a lil to late my rings had sezed up an only way it would run is if u roll it off soo iam rebuilding mine now sould be done tues when i get my parts good luck.....Rick
Shooterj2003
Jun 21, 2015 09:02 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
littleatvr
May 18, 2000 07:45 PM
dunc_n
Aug 26, 1999 09:32 PM
