2000 foreman 400es shifting issue
Old Jul 9, 2007 | 07:35 PM
fmfkid250's Avatar
Default 2000 foreman 400es shifting issue
It shifts threw all the gears at low speed but after going fast it will not shift anymore...
also the speedo is not working I would geuss these go hand and hand
does anyone know where and how to check for the speedo sensor?
Old Jul 9, 2007 | 10:50 PM
Gimpster's Avatar
Check the shift control motor first by removing it and connecting a 12 volt battery + and - terminals to each wire leading to the motor. Then switch them around. If the motor checks out by spinning both directions freely, it is most likely in good shape. If it needs to be tapped on to get going or spins slow and gets hot running in a short period, it is bad.
If the control motor makes a bad contact while running, the ECU will "see" an error and shut the electric shifting down. Usually in this phase the meter will read -- where the gear position should be displayed, and when the key is turned off and back on, it will usually shift again.
I have seen the symptoms you describe many times on units of that year. 9 times out of 10 the speed sensor is the culperate. The key is in what you said, the speedo freaks out before going into default shut down of shifting.
I would proably replace the speed sensor
The manual will only list a continuity test for the speed sensor wire from the control unit to the speed sensor connector. No pulse signal spec is listed for it.
When I diagnose pre-2002 foreman, I will take it out and run it to the rev limiter in 3rd gear and let off the throttle. If the meter draws a blank, speedo wierds out and the unit can not be shifted without using the emergency shifter, the speed sensor is faulty
----- Gimpster -----
Old Jul 10, 2007 | 12:58 AM
fmfkid250's Avatar
I bet its the speedo sensor...it always says 0mph
Where is that sensor on the quad? there is one in the back and one in the front im not sure witch one does what..
thank you for your responce...btw
i bought the thing pulled it off the truck drove it up the street and fkn junk...
I paid $2000 for it I dont know if i should call the guy or not? when i test ran it it shifted fine up and down his 50' driveway
Old Jul 10, 2007 | 01:10 PM
HondaMechanic's Avatar
The speed sensor must work for the ESP to work properly ... The speed sensor is at the rear left on the engine , just above the output shaft (drive shaft) ...
greg74
Sep 10, 2019 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
