Oil in Airfilter box ??? Grizz 450
Morning All,
So I went to clean my airfilter last night and found about an ounce or so of CLEAN oil in my airbox!!! What gives?
I use Spectro Air filter cleaner to clean it, then Spectro Air filter oil to oil it... I am thinking I might have used too much Air Filter oil and it just dripped out???
Any Clues on what is going on? The engine oil is not lower, it is at the same level!
Your crankcase vent hose hooks up to your airbox. When you run your quad it sucks the oil vapors out of your crankcase and it settles in your airbox. That may be some of the oil that you are experiencing also.
<div class="FTQUOTE"><begin quote>Originally posted by: fastquad02blaster
Your crankcase vent hose hooks up to your airbox. When you run your quad it sucks the oil vapors out of your crankcase and it settles in your airbox. That may be some of the oil that you are experiencing also.</end quote></div>
Ok... so is this a NORMAL condition???????
