Anyone Ever disconnect the Rear Sway-bar??
Old Jul 13, 2007 | 12:31 PM
CraZySteve's Avatar
Default Anyone Ever disconnect the Rear Sway-bar??
Hello All,
Anyone ever disconnect the rear-sway bar (if equipped with IRS) before? I would think you would get more independent wheel travel
Any thoughts?
Old Jul 15, 2007 | 11:35 AM
JohnO's Avatar
You do. Mine never had a swaybar - Arctic Cat 500i. What I've noticed in comparing it to a swaybar equipped IRS quad (grizzly) is that it crawls over terrain better, but it also leans in turns more. I can crank up the springs and get better handling, but then it rides rougher and loses a bit of wheel articulation. As most of my riding is over rough trails, I prefer a looser spring setting for better crawling, at the expense of overall handling.
So if you're hitting real rough terrain, no swaybar is probably better. If you like good handling at medium to high speed, swaybar is better.
STLyamwar
Jul 25, 2020 04:44 AM
snowolson
Aug 31, 2015 03:51 PM
Dammar
Aug 26, 2015 07:12 PM
DeFox500
Aug 14, 2015 05:59 PM
rcappie4
Jul 10, 2015 04:54 PM
