Blaster Problem
Old Jul 13, 2007 | 09:33 PM
MTN13's Avatar
Default Blaster Problem
I have a 2002 yamaha blaster that i just bought. it has a big bore kit on it. I had to do some things to the stator and the clutch when i got it. i got it running but it will not idle. i have checked the carb for fuel and it is running fine. I took to carb apart and cleaned it as well. I also took the air filter off and cleaned that but still no luck. I do not think that the quad is getting all of the power it can it bogs down in first gear but when i get into a higher gear it takes off. Does anyone have any idea what i can do. I have tried all I can think of but maybe i am overlooking something.
Thanks
Old Jul 14, 2007 | 03:20 PM
fastquad02blaster's Avatar
The ignition timing might be off enough to not let it idle but when you get into the higher rpm it will run fine. You might double check your stator and all that's going on in that area. The only other thing I would've suggested would be the carb. but you cleaned it so I really am just guessing here.
Old Jul 14, 2007 | 03:22 PM
That kind of sounds like my old bike.
Old Jul 15, 2007 | 04:51 PM
MTN13's Avatar
tanks for the suggestions i will give them a try
Old Jul 15, 2007 | 05:07 PM
lucasislight's Avatar
if a blaster carb has an idle speed screw make sure it is in proper adjustment. maybe its not turned up fast enough. or check your idle mix screw if there is one, make sure it is in proper adjustment. i dont know alot about blasters, but thats where i would start.
Old Jul 19, 2007 | 06:49 PM
punkisbetter2003's Avatar
adjust the idle screw on top of the carb
check the reeds
thats what mine did and i was ready to get it rebuilt but it was only a $8 piece of plastic
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
