gear box issues help
Old Jul 14, 2007 | 09:11 PM
kdrifter540's Avatar
Default gear box issues help
Trans question I just picked up a 86 TRX 70 for $250 the thing won't go into first gear. I have never to messed with a gear box. But there is a first time for everything any suggestions on what the problem could be?
Do I have access to the gear box by taking the right side case off? or do I need to take the engine off and crack the case?
Old Jul 15, 2007 | 07:29 AM
HondaMechanic's Avatar
The center crankcase must be split to work on the transmission .. The shift linkage can be checked by removing the clutch cover .. Do the other gears work ..?.. It is a 4 speed transmission..
Old Jul 15, 2007 | 11:25 AM
yeah its a 4 speed it won't shift into first from neutral
Old Jul 15, 2007 | 12:14 PM
There are pins on the end of the shift drum , the gearshift arm uses these pins to turn the shift drum .. Something is either wrong with the 1st pin or the gearshift arm ..
Here is a picture of the gearshift assy. from the Honda Com website ..
when the picture opens click again for full size ..
http://img517.imageshack.us/my...image=70geararmjw6.jpg
Old Jul 15, 2007 | 01:33 PM
maxskids2000's Avatar
hey guys ,not sure who to ask,
i have a 83 atc honda 200E with hi lo gears .i took off the cover .there is two shims (washers ) and the gizmos inside the cover. i want to reassemble the cover with the gizmos but am not sure of the process,any body can help???
Old Jul 15, 2007 | 01:42 PM
go to the bottom of this page and put in your model and it will show you diagrams
http://www.mrcycles.com/fiche_select.asp
Old Jul 15, 2007 | 03:36 PM
thanks for the site man i'll try to interpret the stuff
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
