esp codes
Old Jul 14, 2007 | 09:39 PM
hollie's Avatar
Default esp codes
i have a 400 rancher at the esp code is flasing 5 to 6 times put a new angle sensor on it and it is still acting the same, what else could it be?
Old Jul 15, 2007 | 07:16 AM
HondaMechanic's Avatar
Default esp codes
First did you put pre-load on the angle sensor when you installed it and was the ECM initialized when you finished ..?..
Both codes 5 & 6 are angle sensor system codes (but that doesn't mean the angle sensor is bad) code #5 is the "motor lock" code , Code #6 is "swash plate angle" ..
Old Jul 15, 2007 | 02:52 PM
Gimpster's Avatar
Default esp codes
Good point HM
I have also seen melted wires from laying against a hot motor bring on those codes
----- Gregg -----
Old Aug 20, 2020 | 11:43 AM
COOP76's Avatar
i made a mistake about my code i was having a #4 code wich is A Tp code I am a big Dummy
goyard74
Aug 20, 2020 11:49 AM
hollie
Jul 24, 2007 01:14 PM
doc1960
Jan 15, 2007 12:16 AM
Atvstevo1337
Feb 8, 2006 03:37 PM
