04 yamaha warrior
Old Jul 16, 2007 | 12:21 PM
hummer93516's Avatar
Default 04 yamaha warrior
Hey i have a 04 warrior the only mod it has is a supertrapp muffler. anyone know how to make it faster with out putting alot of money in it . and how fast does a stock one go?
Old Jul 16, 2007 | 01:18 PM
Raptor450's Avatar
It's hard to make a Warrior "fast". How fast do you want it to be? The best mods you can do are: Better air filter(K&N), a good cam(Webcam or equiv), 366 cc 10.5:1 JE piston kit, and a 14 tooth front sprocket will give you decent power without spending a fortune. With these mods I was keeping up with 400EXs. If you want to spend a little more, get the larger Kibblewhite valves, which are pretty cheap, but you have to pay for your head has to be machined a little. For $200-350 you could get your head ported & polished. If you do all that and its still not fast enough, sell it and buy a faster production bike.
Old Jul 16, 2007 | 03:52 PM
is a header pipe worth putting on?
Old Jul 16, 2007 | 08:19 PM
Raptor450's Avatar
Dont waste the money on a header pipe for a Warrior. Every experienced ATV engine builder I talked to said the factory header pipe is fine and that an aftermarket rev box does nothing for a Warrior. A stock Warrior should run around 55-58 mph. I had a stock Warrior that I took to to the dragstrip and got 55 mph out of it in the 1/8 mile. I did the first mods listed above with the 366 kit and went back to the dragstrip and got 65 mph out of it. I havent been to the dragstrip since the 446 kit, but just messing around in some fields I am getting beat by stock YFZ450's by 3 bike lengths.
Old Jul 19, 2007 | 12:58 AM
kyledvor61's Avatar
raptor 450 what was your E.T. for the 366 kit? i'm doing 7.80's.
Old Jul 19, 2007 | 06:50 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: kyledvor61
raptor 450 what was your E.T. for the 366 kit? i'm doing 7.80's.</end quote></div>
I don't remember, it's been a couple of years ago. Im gonna try to go again soon to see what the 446 will do.
Old Jul 20, 2007 | 03:03 AM
kyledvor61's Avatar
O yea and were you topped out at the 1/8 or were you still climbing? What do you think your 446 tops out at? i was looking at getting a 446 kit also but who knows. When you head out to the track let me know what you run.
Old Jul 20, 2007 | 01:10 PM
Is the muffler i have on it now(supertrapp) good or is there a better one i should put on? and what about a jet kit?
Old Jul 20, 2007 | 06:41 PM
Raptor450's Avatar
O yea and were you topped out at the 1/8 or were you still climbing? What do you think your 446 tops out at? i was looking at getting a 446 kit also but who knows. When you head out to the track let me know what you run.</end quote></div>
It was still climbing, but I was almost topped out. I had stock rear gearing with a 14 tooth front sprocket & 20" tires. I would guess the 446 will top out around 69-70 with the same gear setup. On the road topped out long distances the 450s will only leave me by about 6 car lengths. I could go with a 15 tooth front sprocket, but I like my gearing now. About the 446, I would not recommend it. The only reason I did is because my crank was locked up and the cylinder was scarred with it bored 80 over and the 446 was almost as cheap as the factory crank and sleeve. The 446 really didnt impress me a whole lot. For the money, you can't beat the 366 and you still have your reliability. I hope to take it to the track soon (after I replace the head gasket, again)[img]i/expressions/face-icon-small-frown.gif[/img]I'll let you know what it does.
Old Jul 20, 2007 | 06:45 PM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: hummer93516
Is the muffler i have on it now(supertrapp) good or is there a better one i should put on? and what about a jet kit?</end quote></div>
There are better slip-ons out there. HMF is the first to come to mind. Dynojet is a poular jet kit company. You need a jet kit now if your bike runs lean. If it is running fine, you will need a jet kit later if you get a filter, better pipe, or do engine mods.
