200s front bearings size
Old Jul 16, 2007 | 05:48 PM
loadder's Avatar
Default 200s front bearings size
since no one answered my ? on right or left threads, i assume they are righty, anyways, i cant get the damn axel out, so i am wondering if its possible to slip a new bearing over the nut and move on with it, and if so , what size is the bearing, all i can get from the dealer is its a 6300 series, i need a size so my bearing buddie can hook me up, a little help would be nice, i am also having problems with the pull start not working all the time, it seems to not want to engage until i take it apart and spray with wd40, the plate that holds the 3 teeth back seems to like to stick, is there a part i am missing in there i dont know about ??
Old Jul 18, 2007 | 12:37 AM
KNOWSALOT's Avatar
The Facility
The front bearings are 6302...same bearing that fits the front axle of every Honda ATC made larger than a 110. (even fits the later models of the 110). Should be no problem to find.
The recoil problem is likely due to corosion under the pulley on the main spring...and/or the spring under the friction plate itself. I would disassemble and clean everything and go from there. (Dont let the large spring come "unglued" on ya or you will be there a while untangling it and winding it back up)
Old Jul 18, 2007 | 03:33 PM
loadder's Avatar
thanks, thats the number i needed to know, and i have already had them pull starters apart and had to rewind them, kinda got it down now, but i will remove all and clean it again, i guess leaving it out in the rain didnt do it much help...
KimSJoh
14
Jul 18, 2015 07:20 PM
RedRancher
Jul 10, 2015 06:36 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
