Rookie Needs Help
Old Jul 17, 2007 | 01:05 PM
kiloc1's Avatar
Default Rookie Needs Help
Help,
My TRX250 2006 gave me trouble starting about 1 month ago. Finally got it going and it ran fine. Has been sitting for about 3 weeks now it would not start. Started with the choke on. Once I took choke off it stopped. Then it did not turn on at all any more. New Rider, what could be the problem.
Old Jul 17, 2007 | 01:39 PM
RedRubi's Avatar
Start by cleaning the fuel system, including removing the carb and cleaning the jets and bowl. Napa sells a 2 gallon carb cleaning bucket with a basket for soaking them in. To prevent this happening again,
1. Start the engine at least every month to run the old gas out.
2. Put preservative in your tank during off months when you don't ride.
I have been doing this for 15 years and haven't had a problem in the 15 years.
Old Jul 17, 2007 | 03:09 PM
kiloc1's Avatar
Thanks, RedRubi
I will try that. Just called a local bike and atv shop and they wanted to charge me 150.00 for service, talked about adjusting the valves and rebuilding the carb. I am thinking my atv is only 1 year old, So hopefully this works and will save me alot of headache and money.
thanks again
Old Jul 17, 2007 | 05:51 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You should have done a valve adjustment at 20 hours, just after the engine is nicely broken in! This is the most neglected piece of maintenance there is...most folks NEVER do a valve adjustment, much less the 20 hour one.
At 20 hours, my 06 250's valves were very tight!
Nazz26
Jul 30, 2015 11:51 AM
stocks
Sport Quads
18
Aug 1, 2005 01:37 PM
drnkmixr
Dec 2, 2004 07:39 PM
Willfulone
Nov 11, 2002 07:23 PM
