need help!!!
Old Jul 24, 2007 | 05:10 PM
coachs's Avatar
Default need help!!!
After the quad gets hot it just stops moving like someone shifted it into neutral. Motor is idling fine but will not go. One more thing I just cleaned the carb. was riding the four wheeler just for a few minutes and it actedl like some one cut off the air to the machine. I know that wasn't possible because the air breather wasn't even on. Thanks
Old Jul 25, 2007 | 07:15 PM
cchucky51's Avatar
check to see if you might have pinched one of the air hoses on the carb when you put it all back together, i would check all air ducts from drive area an check the belt
Old Jul 26, 2007 | 02:20 PM
samk's Avatar
Is the engine bogging (ie not accelerating) or does it rev up fine but just not move? I tore down my carb (same bike as yours), cleaned & reassembled. Upon restart it ran good when cold but was sluggish taking off when hot. I readjusted the idle mixture and it seems fine not.
Still have some sort of issue with the top end though. Doesn't seem to want to gain any speed from 3/4 throttle to full. Not sure if it's in the clutch/trans or engine???
