maybe carb problem?any ideas?????
Old Jul 24, 2007 | 06:20 PM
longanddeep's Avatar
Default maybe carb problem?any ideas?????
i have a honda atv 1985 and i just rebuilt the carb.. it runs good when its sitting still but when i go run it around the yard after about 5 min its start to lose power then stall..the only way to get it started is to use the choke and even that is alittle hard but once its running i have to keep giving it gas then maybe it will give me enough time to put it in first...its got to be the carb but not sure!!!!
Old Jul 25, 2007 | 02:43 AM
2XVision's Avatar
It`s obviously running out of fuel, as the choke indicates that. On the bottom of the carb there is a drain that has a flat head slot in it, turn the bolt counter clockwise and see if any fuel comes out. If none comes out you`ll have to go in and find out why. It sounds as if the float is sticking shut.
Old Jul 25, 2007 | 01:53 PM
thanks for the reply!!! i will try this weekend!!!
Old Jul 25, 2007 | 02:02 PM
hondabuster's Avatar
Also check for pinched off vent lines, or a gas cap which wont vent properly.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
UPLou
Jun 7, 2015 09:42 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
