Kodiak carburetor
Old Jul 24, 2007 | 07:19 PM
MDHunter's Avatar
Default Kodiak carburetor
If it's in the owners manual, I missed it, but always run the fuel out of your Kodiak (and probably all.) Just rebuilt carb, no new parts but cleaned the jets and bowl. All were slightly corroded, but the needle valve was sticking. Would run until bowl was dry, then wouldn't start. Let sit for a 1/2 ht or so (bowl would refill) and it would repeat.
It's not too hard to take apart, but be careful of tank bolts. They seem to strip easily when reinstalling because of misalignment. If you don't have a set of (oxy/acetelene) tip cleaners, get a set. They were invaluable.
When putting the bike up for a few days or if you don't know for how long, turn the tank to off and run until carb bowl dry (stalls.)
Old Jul 25, 2007 | 12:01 PM
CraZySteve's Avatar
Ok... so how old is your Kodiak? Do you store your quad outdoors where it is subjected to moisture and temperature differences? Is it a Kodiak 400? 450? More info please...
Old Jul 25, 2007 | 01:13 PM
MDHunter's Avatar
05 Kodiak 450 stored in my garage, but ridden infrequently. Frequency is the biggest problem. Has only 55 Hrs on it. Use it for hynting, so doesn't get a whole lot of use except for Sept - Jan.
Old Jul 25, 2007 | 02:06 PM
hondabuster's Avatar
Its even worse when you use ethenol blended gas. My motorcycles owners manual states, dont store the bike if ethenol is in the tank....use pure gasoline only. Its ok to drive it with ethenol in the tank, just dont let it sit for awhile with it in there. It dries into flakes and solids, and those end up plugging the small passagaways. The smaller the motor...the smaller the carb..the smaller the passagways. The kids sized quads suffer the worse.
Old Jul 25, 2007 | 04:57 PM
MDHunter's Avatar
I can't get anything but ethanol 10% gas around here. Guess I'll just be more careful. I'm surely not concerned about tearing into the carb any more.
YankeeRebel
Oct 6, 2015 06:44 AM
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
RedRancher
Jul 10, 2015 06:36 PM
