blaster
Old Jul 13, 2007 | 12:40 PM
dRIfTeR4's Avatar
Default blaster
I was out riding my four-wheeler last night and
I decded I'm gonna get
a pipe and a reed for it I guess it really wakes
them up what one makes more of a difference??
The pipe or the reed?
Old Jul 13, 2007 | 02:12 PM
fastquad02blaster's Avatar
Default blaster
I put an ex. chamber and a silencer on mine along with an air filter. I rejetted the carb to go along with my mods so that it wouldn't be too lean. That really woke up my blaster. The pipe gives you way more power all throughout your rev range. If you put a pipe on it you won't be dissapointed. The reeds give you more off idle power and some throughout. I'd put on a pipe and see what you think.
Old Jul 19, 2007 | 06:52 PM
punkisbetter2003's Avatar
Default blaster
try
pipe and silencer
reeds
air filter
rejet it
Old Jul 20, 2007 | 12:33 PM
dRIfTeR4's Avatar
Default blaster
Ok ill put them on this weekend and test it out and im pretty sure ill get a good result.!.!.
Old Jul 20, 2007 | 12:34 PM
dRIfTeR4's Avatar
Default blaster
But......................
...............why do
i need all of them?
Old Jul 20, 2007 | 12:36 PM
dRIfTeR4's Avatar
Default blaster
Shouldnt i just neeed the pipe and reed?
and oniously i need a air filter for it to run...
Old Jul 20, 2007 | 04:23 PM
way2fst's Avatar
Default blaster
of course you would need a jet kit, otherwise..well...it'll break...
if you get a pipe , reeds , and a new air filter, you will be set as far as breathing goes...
Old Jul 20, 2007 | 05:27 PM
dRIfTeR4's Avatar
Default blaster
Well why do you need to get a new airfilter???
And do you have to get a new one?
Old Jul 21, 2007 | 12:42 AM
way2fst's Avatar
Default blaster
no but if you are letting more air out (via the new exhaust), it only makes sense to upgrade to a after market filter in order to let more air in. if you are already running a k&n, or uni, or any other after market filter, you dont need a new one. an after market filter will complement the exhaust, and together you will notice a bigger power increase.
Old Jul 21, 2007 | 08:19 PM
Default blaster
Engines are glorified air pumps. The more air you can pump from a smaller engine the more power it has. Lots in and lots back out = HP.
