Help! 500 Sportsman Power Loss
Old Jul 25, 2007 | 03:42 PM
BigPolarisDog's Avatar
Default Help! 500 Sportsman Power Loss
I have a 1999 Sportsman 500 that is giving us fits. It started to lose power on hot days this spring. Will start & run but has no power and might go 30mph. We adjusted the clip in the carb a couple of clicks to get it more fuel and seemed to help until the summer hot weather came. So we adjusted the clip to the last spot the other day and seemed to run great for a few days of 90+degree weather.
Then we used it yesterday for a football camp hauling water around to players all day and by late in the afternoon it acted up again, worse then before.
We have checked the valves and it has good compression. We also sprayed ether around the carb to see if there were any seal problems. We are totally baffled at this point.
Any suggestions are appreciated as my mechanic is confused and I'm barely mechanical enough to change the oil in my mowers!
Thanks!
Old Jul 25, 2007 | 04:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure in what yrs. but they had cam problems in the late 90's where the lobs off. may be a cam problem where its loosing power. just a thought for ya.
Old Jul 25, 2007 | 04:14 PM
Actually had the pleasure of replacing that a couple of years ago[img]i/expressions/face-icon-small-happy.gif[/img]
Thanks though.
Old Jul 25, 2007 | 04:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you said you adjusted the valves as it would loose power if they were to tight when they get hot so you ruled that out. what about vent lines to the carb and the gas tank. there all clear and not pinched cutting off breathabilty? thats all i can think of.
Old Jul 25, 2007 | 04:45 PM
sled05's Avatar
I would disassemble carb and clean jets. Make sure you dont have old fuel in tank.
Old Jul 25, 2007 | 05:20 PM
Vent lines are ok and just filled her up yesterday
Thanks
Old Jul 25, 2007 | 05:47 PM
Is there any way this could be electrical at all? Like I said, I'm not very bright about this stuff but I'm reaching at straws here.
Old Jul 25, 2007 | 09:49 PM
ftwflh's Avatar
Check the secondary clutch ramp buttons.
Old Jul 25, 2007 | 11:46 PM
duffus's Avatar
is there oil in the air filter box? if so, might be just worn out rings. How many hours or miles are on the machine?
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
