Sprockets / Oil
Old Jul 27, 2007 | 01:29 AM
krazed's Avatar
Default Sprockets / Oil
I know theres a lot of equations and factors to this, but I really don't remember them. [img]i/expressions/face-icon-small-tongue.gif[/img] I've been out of the ATV tuning scene for a while.
I have a warrior, and I'm looking for a sprocket meant for more mid-range and top end? Would I go with smaller front, larger rear? Or what?
Also, one other question. I'm pretty sure it's 10w-40 oil, but how many quarts does it take?
Old Jul 27, 2007 | 09:48 AM
lucasislight's Avatar
if you want a faster topend, either a larger front sprocket OR a smaller rear sprocket will help you there, i use 3 quarts of oil. i think the clutch cover says 2500cc on it.
Old Jul 27, 2007 | 10:36 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
2.8 quarts is the best for it.. 2500 is without a filter change i do beleive( not 100% sure though)
don't go too large of sprocket, you'll just bog the quad down when you go up hills and such.. also.. you won't get better mid-range and top end.. either one or the other.. i say that because like right in between low and mid is the best for climbing hills and when u run a big sprocket you have to use a lower gear
ok u know what.. the gain you will see is fairly minimal.. 2-3mph per front tooth you go up.. is it worth it to you?
Old Jul 27, 2007 | 12:26 PM
krazed's Avatar
Yes, and no. I ride with a lot of 400's, 450's, etc. And we do a lot of road riding, so a larger top end would be much better. If say I went up 2 front teeth, I'd gain somewhere around 6mph top end? How much bottom and mid would I lose?
Old Jul 27, 2007 | 01:03 PM
Speedy2222's Avatar
you'd notice a difference in takeoffs( clutch stress ) and 3rd gear hill climbing.. 4th gear is out of the question
Old Jul 27, 2007 | 05:04 PM
krazed's Avatar
Now, being that if I was feeling clutch stress, would that also mean It'd lead to clutch replacements?
Old Jul 27, 2007 | 05:31 PM
Speedy2222's Avatar
it may.. there would definitely be more stress against the clutch at startups along with hillclimbs and such.. clutches are cheap though.,. $35 or so for a full set with springs
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
