WORKS TRIPLE RATE REZZIES..HOW DO I ADJUST THEM
Old Jul 29, 2007 | 06:19 AM
wsy480's Avatar
Default WORKS TRIPLE RATE REZZIES..HOW DO I ADJUST THEM
I BOUGHT SOME WORKS TRIPLE RATE REZZIES THEY ARE USED BUT WERE JUST SERVICED WAS WONDER IS THERE ANYWAY TO ADJUST THEM AND HOW AND AND WHAT WILL IT DO....PLEASE HELP JUST WOULD LIKE TO MAKER SURE IM GETTING THE MOST OUT OF THEM...THANKS
Old Jul 30, 2007 | 06:34 PM
velocyraptor's Avatar
how adjustable are they? preload adjustable, compression, rebound? any ***** to turn? do the rezzies have a ****? more info
Old Jul 31, 2007 | 01:54 AM
wsy480's Avatar
kinda what im asking the only obvious thing is a air valve on the rezzie for nitrogen..but thats all i can tell
Old Jul 31, 2007 | 10:52 PM
thats compression, if you jump alot set it a little stiff so it doesnt bottom out and play with the compression to see what set up you like
Old Aug 2, 2007 | 11:02 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have had these on several quads over the years (Steelers w/rez front and Ultracross rear), and they are outstanding shocks! The set on my 400EX, have not been serviced or rebuilt in years (guess I'm just lazy), and they are still going strong.
http://atv.off-road.com/atv/ar...eDetail.jsp?id=192286
First off, sounds like you are talking the fronts here, right???? You need to begin by adjusting preload/ride height. This is best done with a tool that will hold the spring compressed. (I got one from White Bros, and it is well worth the money to have one of these!) Once the spring has the tension off it, there is a clip that you move up or down, as you wish. Really simple.
Compression damping is the screw on the can, and rebound damping (if you have it) will be somewhere on the body of the shock. DO NOT mess with the nitrogen valve....DO NOT try to refill it yourself!
BGC
Utility ATVs
Oct 7, 2015 11:50 PM
txkevin
Sep 21, 2015 02:02 PM
cornermike
Jun 3, 2015 07:27 AM
dosthoff
Jan 3, 2000 10:04 PM
Team400EX
Nov 19, 1999 07:21 PM
