best warrior mods
Old Jan 1, 2001 | 12:50 AM
Benploarisman's Avatar
What are the best warrior mods I could put on my warrior. I don,t want to spend alot of money.
Have there been any cases of warriors over heating.
Old Jan 1, 2001 | 01:58 PM
warrior35000's Avatar
A pretty good mod to start with is the K&N Power Kit and to cut holes in your airbox, the kit is $130 and you get your moneys worth. My warrior has never over heated. Good luck
Old Jan 1, 2001 | 07:42 PM
PC_350_Warrior's Avatar
Go with a good pipe....like the White Brothers E-series for a lil over $200 big diff! Then if you want more power get a mild cam and stiffer valve springs.
Old Jan 4, 2001 | 08:21 PM
thenewfiebullet's Avatar
Do stiffer valve springs actually make more power, or just allow you you to rev the motor higher, thereby making a few more horses? I understand that stiffer springs would allow for more consistant performance, but I'm not sure you'd really notice a difference in power output.
Old Jan 4, 2001 | 09:57 PM
waynaferd's Avatar
The only thing stiffer springs are good for is if you have trouble with valve-float(when the valves are moving to fast and are boucing off thier seats), which they shouldn't do unless you miss a gear or break a chain while going full-bore.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
