Rebuilding Foreman Axl
Old Jul 31, 2007 | 11:48 PM
bluduk15's Avatar
Default Rebuilding Foreman Axl
1998 Foreman 450 S: Berings went out on the left rear wheel and I bought the replacement kit for the whole rear end. I've already replaced the brake drum that includes the berings.
While I've got this all apart, what else should I do?
Thanks,
bd
Old Aug 1, 2007 | 08:54 PM
79hugger's Avatar
If the brake panel bearing is wore usually the one at the pinion in the carrier case is bad to, which I'm sure you replaced both. Be sure to break the drain plug loose on brake plate and put some antiseize on it so it wont be a pain later to drain out any water and degrease the new drum to get any factory lube off it, sounds like you got it though,any questions,be happy to help if I can
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
