Helicoil
Old Aug 1, 2007 | 07:04 PM
pcollins's Avatar
Default Helicoil
Hi has any one every helicoiled an atc 70? if so was it hard at all? Just want to see if I am going to have problems before I start.
P.S.- The helicoil part for the atc 70 is hard to find, so if you need one, here it is:
Helicoil
Old Aug 3, 2007 | 04:47 PM
JkAss's Avatar
Default Helicoil
Where are you installing the helicoil?
Old Aug 3, 2007 | 04:50 PM
pcollins's Avatar
Default Helicoil
the spark plug hole
Old Aug 3, 2007 | 05:03 PM
JkAss's Avatar
Default Helicoil
Just make sure you use red loctite or it could come out with the plug when you change them.
Old Aug 3, 2007 | 05:20 PM
pcollins's Avatar
Default Helicoil
ok thanks
Old Aug 5, 2007 | 01:21 PM
JkAss's Avatar
Default Helicoil
Also make sure to check that the plug depth is the same as stock or you could run into problems. If too deep your piston could hot it or if not deep enough it would run crappy. I've seen both senerios personally [img]i/expressions/face-icon-small-smile.gif[/img] and they will drive you crazy trying to figure out why it is not running right.
Schneider600
Nov 21, 2007 12:14 AM
NickDS650
Aug 30, 2006 03:19 PM
maddog56
Sep 28, 2005 12:39 AM
jarret22
Jun 27, 2005 03:38 PM
