brakes?
Old Aug 4, 2007 | 09:52 PM
furnaceman's Avatar
Default brakes?
Well Iwas wondering if you guys could help me out here? I was out riding today, 96 sp 500. I was using the brakes they worked fine until one hard stop and bamo, no pressure. I looked for leaks and sure enough found a pin hole leak in the rear brake line. I fixed the line by splicing in a new section, yes double flared. I went to bleed them and have no brake pressure. I get some fluid but not much. I tried hooking up my hvac vaccum pump to it and was able to suck fluid through the line. I took off the line from the master cylider and got a squirt or two but not too much. is it possible the seals in the master cylider took a dump when the line lost pressure? man i was thinking this will be a quick easy fix,LOL.
Bill
Old Aug 5, 2007 | 10:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default brakes?
it is possiable that the hard stop didnt do the master cylinder any good. make sure theres good pressure at the handle. i hear once theres air in the brakes their a main to get out.
Old Aug 5, 2007 | 04:09 PM
furnaceman's Avatar
Default brakes?
well, I tried everything I know. pulled 20oz of brake fluid through the lines out the bleeders and still nothing. I think I'm going to try to rebulid the cylinder. does anyone know how the heck this thing comes apart? I would love to do a rebuild at about 40.00 verses 124.00 for the whole thing.
Bill
Old Aug 5, 2007 | 06:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default brakes?
w/out looking im guessing there should be a c clip that is at the handle end that holds the piston in place. take that out and it should pull out. im not 100%sure w/out looking though.
Old Aug 5, 2007 | 06:39 PM
furnaceman's Avatar
Default brakes?
Well I put it all back together and found some how my foot pedal was working again, so I went for a ride. All through the ride I was trying to use the handle. After about two to three miles of riding the brakes are back! wow What a pain that was. I think I must have had a nasty air bubble in the master cylinder. All is weel now after 2 days of messing with it, thanks for the insight sten!
Bill
Old Aug 5, 2007 | 09:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default brakes?
hey glad is all fixed. them damn air bulbs between the brakes and the radiators i dont whats worse. pretty stubon buggers.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
