Recoil help on 250 trailboss
Old May 9, 2007 | 01:05 AM
Raptor010101's Avatar
Default Recoil help on 250 trailboss
I recently bought a 90 250 trailboss and the outer recoil is off it. I am confused as this seems different from the typical honda or snowmobile recoil. The fiche I found shows that on the outside half of the recoil there is only the plastic wheel part that the rope winds on?? IS this correct?? The rest is behind the other cover closer to the motor. I have the outer cover and the plastic wheel but do not know how it connects to the inside parts. there must be a bolt i do not have. My question is this special bolt or what do i need??? The fiche does not show a bolt there?? Can someone explain this to me ??? Thanks
Old May 9, 2007 | 03:14 AM
TLC's Avatar
TLC
Go to this site Parts for polaris and see if the schematics help you out.
Old May 9, 2007 | 01:05 PM
I have already done that????????.... I above stated the fiche does show any bolt???
Old May 9, 2007 | 05:26 PM
cdrmotorsports's Avatar
Do you mean where the bendix is? Are you looking to get to that? To get to the bendix or the inside of the pull starter you need to take the five or so bolts off of the pull starter housing and the whole houseing will come off. I think you just have the cover off, right? Did you remove the black cover or the whole thing?
Old May 9, 2007 | 05:58 PM
Thanks for the reply.
When i bought this the guy handed me the outside cover and the plastic wheel the rope winds on. The inside cover is still on and there is an open hole in the middle of it. My question is what holds on the plastic wheel some sort of bolt or what am I missing here??
Old May 9, 2007 | 08:07 PM
Now I understand your question, but I don't have an answer for you. My pull cord is in pieces right now. Somebody on here will be able to help you out. Good luck.
Old Aug 5, 2007 | 09:49 PM
hankb's Avatar
Dude did you ever get any help on the removal of the plastic spool? I have the same problem! Hank Bailey 903-874-5323
68_327_c20
Nov 25, 2023 12:26 PM
Dammar
Apr 20, 2016 06:03 AM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
Desimation2k8
Jul 17, 2015 12:37 AM
