Drive Train Trouble on 450 foreman
Old Aug 6, 2007 | 09:10 PM
colin26's Avatar
Default Drive Train Trouble on 450 foreman
Was Ridding My 450 foreman had it in 4 wheel drive when my rear wheels stopped working, only front wheels are spinning now any suggestions, on the problem please help!
Thanks
Old Aug 7, 2007 | 12:00 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
So the back wheels spin freely, but just don't get any power????
Old Aug 7, 2007 | 11:36 AM
colin26's Avatar
yeah thats right just stopped working no crunching sound nothing, made for a long ride home had to go in reverse up all the hills.
Old Aug 7, 2007 | 11:45 AM
Red Rider
I would put it up on a stand, with all 4 wheels off the ground. Hold onto the drive shaft while you spin the rear wheels. If the rear wheels/axle will spin, yet the drive shaft doesn't, then you have a problem with the rear drive hub....like some stripped gears in there. If you drain the oil on the final drive, is it full of metal shavings????
On the other hand, if spinning the rear wheels also spins the drive shaft, then you most likely have a problem in the final drive of the transmission. If you drain your shared engine/transmission oil, is it or your oil filter full of shavings????
Old Aug 7, 2007 | 01:01 PM
HondaMechanic's Avatar
The rear axle splines will be stripped ... If the ring gear splines are also bad (and they probably are) it will need both..
Old Aug 7, 2007 | 04:34 PM
Red Rider
Does make more sense that the splines would be stripped, rather than the gears themselves. Still, you should have lots of crud in your rear drive oil.......
Old Aug 7, 2007 | 09:48 PM
cluby's Avatar
Seen this many times over a summer, and where the splines are there is no oil. They get water in the axle tube then in around the axle and rusts up and pretty soon baby smooth splines.
Old Aug 9, 2007 | 10:30 PM
colin26's Avatar
Thanks alot boys rear axel splines were screwed replaced the shaft back on the trails again.
Old Aug 9, 2007 | 10:37 PM
not tooo heavy's Avatar
im using 20 50 oil in my trx 350 is that good
Old Aug 10, 2007 | 03:29 AM
Red Rider
20W50 in the engine or the rear final drive???
That is ok for the engine/transmission in hot weather, but I would run something lighter in cold weather.
For the final drive, you want an80W90 GL5 "hypoid" gear oil, not engine oil!
