Recon Winch Mount
Old Jan 1, 2001 | 11:11 PM
ReconBoy's Avatar
Does anyone know where the winch mounts on a Recon with a warn or cmp mount or could I make a homemade one that goes under/inside the front bumper that supports a Roller Fairlead.
Old Jan 1, 2001 | 11:36 PM
ReconBoy's Avatar
Somebody , Anybody know
Old Jan 2, 2001 | 12:52 AM
Fourtrax350's Avatar
http://www3.ns.sympatico.ca/atcharleys/
Old Jan 3, 2001 | 02:04 PM
Ursus's Avatar
I can't help you with the Warn or other mounts. I do know that it was quite easy to mount a T1500 Superwinch to my Recon. I have it mounted up under the front rack and fenders to the two large frame pieces the run diagonally down to the steering rods. I used a 1/4 steel plate which the winch bolts to by two holes. I then used 4 large u-bolts to mount the plate to the frame. For the time being I am using a piece of 1/4 dimond plate mounted to the retangular opening on the front bumper below the headlights with a 1/2x3 inch opening as a crude fairlead. It works quite well, although I am going to mount a roller fairlead to the front instead of the diamond plate to increase the angles at which I can use the winch. The winch is worth its weight in gold to me and I would never get another quad without one. The only problems I have had with it is I often need to tie the Recon to a tree inorder to pull the Beartracker out of where it is stuck.
The Bear is a little heavier then the Recon so the Recon has a tendency to pull itself to the Bear instead of pulling the bear to it.
Old Jan 3, 2001 | 04:21 PM
Fourtrax4life's Avatar
Dennis kirk catalouge has one with all the parts customized for the recon only
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
