how to check valves
Old Aug 9, 2007 | 05:21 PM
Matt1980's Avatar
Default how to check valves
I just found out it is 117$ just for valves and id like to know how hard it is to do on my own and what i need to do it.
Old Aug 9, 2007 | 06:05 PM
HondaTechnician's Avatar
If your mechanically inclined, you will need a manual, a set of feeler guages, and a few hand tools. Valve adjustment is a fairly easy task, however not for the light hearted.
Old Aug 9, 2007 | 08:45 PM
HondaMechanic's Avatar
That would depend on the model .. $117 for valve adj. on a Recon is high (it's only 1/2-3/4 hour job .. $117 for adj on a TRX450ER isn't quite so bad (it could need 4 shims at approx. $6.00CDN each) Plus pulling and re-torquing the cam possibly 1-2 times ...
Old Aug 9, 2007 | 11:27 PM
Yes, you are absoulutly right.
Old Aug 10, 2007 | 12:02 AM
Matt1980's Avatar
by the way it is a 1999 300ex
Old Aug 10, 2007 | 12:13 AM
That ones quite simple, remove the fuel tank and you will have access to the valves.
Old Aug 10, 2007 | 12:21 PM
RedRubi's Avatar
My o7 Rubicon is due for the first adjustment, but I'm afraid to let the dealer mechanics work on it. I'll probably do them myself.
Old Aug 10, 2007 | 04:22 PM
The rubi is not to bad... more tedious then anything... removing the plastic and the fuel tank....
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Unzzy66
Jul 11, 2015 10:01 PM
Sjrpp
Jul 5, 2015 09:04 PM
