Charging voltage?
Old Aug 12, 2007 | 03:50 PM
ouch1175's Avatar
Default Charging voltage?
With the quad at idle the voltage holds at 12.3V when running at speed anywhere from 3000 to 5000 RPM the voltage at the battery climbs and keeps climbing.. Westopped it when it hit 15.5V. Is this normal or is the voltage regulator faulty?
Old Aug 12, 2007 | 04:09 PM
HeftyLefty's Avatar
You are fine. 15.5 volts is normal for any 12 volt system. The 15.5 volt output insures the battery is fully recharged to 12 volts.
Old Aug 12, 2007 | 05:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
mines 14.1 @ 3300 rpms
Old Aug 12, 2007 | 07:01 PM
ouch1175's Avatar
Does it hold at 14.1 or does it climb higher the longer you monitor it?
Old Aug 12, 2007 | 07:28 PM
thedoc's Avatar
do all models actually have a regulator?
I put an aftermarket "car type" volt meter on mine and it seems to always be charging at 16 v whilst any speed over dead idle and never drops back as one might expect if a regulator
but after sitting for say 10 minutes with sound system blasting the crocs away, that "surface charge" slips from 13 v back to 12 or so and if after say 30 mins it creeps back below 12 v I know it's time to turn off the sound or it might not want to start
Old Aug 13, 2007 | 07:13 AM
upnort's Avatar
15.5 seems rather high. Would think it should be more in the 14-14.5 range at 3k.
Old Aug 13, 2007 | 06:27 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
My Factory Service manual says 13.0 - 14.6 V D.C with the RPM increased between 3000-4000.
.........Caper...........The manual is for a 2005 SP 400/500 and 2006 SP 450/500
Old Aug 13, 2007 | 06:45 PM
thedoc's Avatar
sorry but I meant to say it sits on 14 V and not 16 V
of course it will all depend on the state of charge of the battery as well as the condition/age of the battery
I know all about this as my home [donga] is solar powered and after 4 years or so those big expensive batteries start to refuse to suck in the amps and the voltage creeps up, at which point the regulator cuts in
then it's $400 for 2 more of those big 6 V suckers
Old Aug 16, 2007 | 10:11 AM
ouch1175's Avatar
Last dumb question I will ask about this.. If I check this at the battery with the quad running, will I get the right reading? Or does that represent something else?
Old Aug 16, 2007 | 04:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you will get the correct reading at the battery. unless you are going above 15 plus volt and blowing lights or others it most likely fine. just my thought.
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
