05 Trailblazer Boggs Down
Old Aug 12, 2007 | 09:44 PM
golfstud88's Avatar
Default 05 Trailblazer Boggs Down
I have a 2005 Trailblazer and it seems if i get down in some water (not fully submerged) the quad wants to bogg down and has no power. What could the problem be? I have already checked the plug and made sure it was tight. Also the air box is dry when it boggs down. Can someone please help?!
Old Sep 27, 2007 | 01:50 PM
RY11's Avatar
Im having the exact same problem with my scrambler,Ill let you know if i figure it out.
Old Sep 27, 2007 | 02:00 PM
scootergptx's Avatar
Supersock
Hired Gun!
Have you put any dielectric gel around the plug boot?
Old Sep 27, 2007 | 02:10 PM
golfstud88's Avatar
I haven't yet but I will definately try that. Thanks
Old Sep 27, 2007 | 02:11 PM
golfstud88's Avatar
I would really appreciate that. Thanks
Old Sep 27, 2007 | 04:05 PM
RY11's Avatar
On my scrambler i just pulled the small front plastic which covers all the electricals and hit it with a spray bottle and it started bogging,so now i am going to try and pin point it.i will keep you updated.
Old Sep 27, 2007 | 04:42 PM
RY11's Avatar
The connector for the regulator seems to be the problem i put lots of dielectric grease on it and then electrical taped it.Then I blasted it with the garden hose and it stopped doing it.Im most likely going to but some grease in my spark plug boot also and hopefully when I get a chance to test it out in a big puddle i will know if Ive solved the problem or not.
Old Sep 27, 2007 | 05:37 PM
drlang's Avatar
Don't forget the pull starter, that is a path to the magneto. Doc
Old Sep 27, 2007 | 06:19 PM
golfstud88's Avatar
OK i will definately try that. Thanks a lot.
neo27ny
May 14, 2018 12:19 PM
fordfaithful21
Dec 7, 2015 05:52 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
