Warrior wont start. Help!!!
Old Aug 15, 2007 | 10:49 AM
roguesix6's Avatar
Default Warrior wont start. Help!!!
Ok, so my warrior will not start. last week i put a alba racing pipe kit on it, including jetting it. After the work was done it started up perfectly and it sounded perfect. Than the second time out riding it for a period of time it sounded like it had more of a bark to it than before and would start to backfire while slowing down and not giving it any gas. After that i would have to pump the throttle to start it again and the only way to get t to idle was with the idle screw giving it a rich mixture, and even than after a few seconds it would cut out. now it just wont start. I checked the spark and it was good, when i put it back in and tried starting it it almost fired up, but that was all. I have absolutely no idea what is wrong, it went from running perfect to running fair, to not running. Any and all suggestions, i am completely lost and am willing to give anything a shot. PLEEEASE HEEEELP!!
Old Aug 15, 2007 | 12:55 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
you probably tore the carb boot between the cylidner and carb.. check it
Old Aug 24, 2007 | 06:51 AM
HONDA CRUSHER 93's Avatar
if you did you can fix it with rubber cement.
Old Aug 24, 2007 | 09:12 AM
Speedy2222's Avatar
any fix should only be temporary.. replace the boot asap
Old Aug 24, 2007 | 10:05 AM
jetmotoracer's Avatar
was it raining or wet.... a similar thing happens to my jetmoto and my friends suzuki..... it usally just has to dry out
Old Aug 30, 2007 | 10:43 AM
RhinoWarrior's Avatar
check the plug and rejet it or get a WB carb which is the better choice I HATE the stock one
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
