Polaris Trail Boss 325 Rear Brakes
Old Aug 16, 2007 | 03:40 PM
brian8211975's Avatar
Default Polaris Trail Boss 325 Rear Brakes
Just bought two Trailboss 325's(01' & 02'). They are very low hours and in great shape. Except the rear brake does not work. That is the rear brake foot pedal provides no stopping force. THe hand lever works and it actuates both front and rear as I understand. But I would like to have the rear pedal working.
Anyone have any ideas? Is this common on these models? I have a buddy with a 330 and it has the same issue.
Thanks in advance.
-B
Old Aug 16, 2007 | 04:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its common on alot of the polaris models. the back brakes set up sucks. if there not used alot like over the winter they tend to lose pressure. you can try to bleed them alot (making sure not to empty the small resiour) or i used a heavy weight to set on my brake pedal over night and brought some of the use back. just an idear.
Old Aug 16, 2007 | 05:08 PM
deanz400's Avatar
yep mine's the same way and the bleed screws tend to seize up ,
Old Aug 16, 2007 | 05:14 PM
scootergptx's Avatar
Supersock
Hired Gun!
Surprisingly mine has worked fine. You can try to bleed them, but you may want to do the whole system.
Or you can do like I finally did on the wife's trail blazer. Accept that it just isn't gonna work.
Polaris will tell you the rear brake is only an assist, and should not be used to stop the vehicle. So technically, it's not a rear brake pedal, but a rear brake pedal decoration.
Old Aug 16, 2007 | 09:05 PM
dirtsnow's Avatar
just bleed bleed bleed & when they go soft again bleed bleed bleed.
make sure u keep the fluid right up to the max!!! make sure your
rear pads are not worn, there is a min. thickness on them. both my
quads have had the rear foot pedal work for over 2 years & will lock
up the rear tires!! hang in there it takes time & effort
Old Aug 17, 2007 | 08:10 AM
spiffinmaine's Avatar
yup same here
Old Aug 19, 2007 | 03:54 PM
scrappiedew1's Avatar
YEAH HAVE THEM BLED MY WIFES 2001 HAD THE SAME ISSUE AND THAT TOOK CARE OF IT.
Old Nov 6, 2007 | 08:04 PM
azcard's Avatar
How do I bleed. is there a manual.
AK47KID
Jul 23, 2015 09:21 PM
wildbill59
Jun 20, 2015 02:26 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
PolarisPower500
May 17, 2015 02:28 PM
